1994 E 150, side doors
This has the double side doors. The cable for the back one that lets it open is broke. How do the panels come off? There are no screws in them and I can't get them to just pop off. Is there any way to just pry the door open. With it shut, you can't access the bottom of the panel, it sits below floor level.
Hi Rusty,
According to memory which is pretty foggy about now, if you have some type of decorative trim panel there should be what was called scrivits and the center unscrewed and allowed the retainers to collapse and then be pulled out of the holes in the door. Is this what you have? You must lift the panel covering to allow the bottom retainers to unhook from the door edge.
Like I stated earlier a little foggy,
the area where the lic plate /door release has a plastic frame that you loosen the screws from the inside and the whole assy comes out. Now you can release the door latch and go from there.. It has been a long time since I played with one of them.
