1994 E150 Intermittent miss
Old 08-30-2011 | 02:20 PM
kennyg's Avatar
Default 1994 E150 Intermittent miss
I recently purchased a 1994 E-150 Conversion, 5.8L engine, AOD trans, with an intermittent miss. Its almost like the key is being turned on/off. It will miss at idle and normal driving, but stops upon heavy acceleration. Runs great other than that. Previous owner replaced plugs, wires, distributor, coil, but didn't get into the fuel system. He stopped short of the computer. Anyone else ever had this problem? thanks
Recently checked all vacuum hoses for kinks/ok, checked EGR/ok, fuel pressure/ok, no codes showing up . . .
Replaced fuel injectors . . . no help :-( THEN, Relaced PCM . . . problem SOLVED!!!! ;-)
thecaptain1997
07-06-2012 08:09 PM
harrisg
06-08-2012 10:05 PM
ac917x
05-08-2012 04:25 AM
chadwoody1234
05-08-2011 08:46 AM
paf150driver
08-12-2009 06:42 AM
