1995 E350 ABS/ Airbag light
I recently bought a used 1995 E350 for a daycare business. the abs/airbag lights came on. Local mechanic said the modules were bad and he couldn't find the parts. Where are they located on the vehicle? Are the easy to replace? Are parts easy to find? Thanks in advance.
Here is a link that might help
ABS troubleshooting guide RABS I 1995 e350 - Diesel Forum - TheDieselStop.com
Have you looked behind the glovebox, I am not sure I am just a diy guy
Hanky, I'm not mad at all, in fact, I' m glad I could amuse you. To clarify for anyone that can or will offer a solution, I meant to say that the local mechanic that I took the vehicle to reported the problems AND also stated that he couldn't find any replacement parts for the vehicle because of its age. Additionally, I was also asking where are the respective ABS/ airbag modules located on the van so I can attempt to replace them myself.
Mich04, thanks again for your help. I was able to fix both the abs and the airbag lights.
The differential sensor ($20 Autozone) cured the abs ailment. The biggest issue was the airbag sensor. Once I physically had the part off, I was able to find a function airbag module at a salvage yard. Less than $50 to fix both. I'm extremely .
aangel
01-16-2009 04:01 PM
