1998 E250 Vent only?
RE: 1998 E250 Vent only?
It could be a vacuum issue, see if you are getting vacuum into and out of the vacuum reservoir. Also check to see if the vacuum lines into the heater control system are ok. Defrost is the default setting with no vacuum applied.
johnnyjohnny
01-10-2012 10:04 PM
