2003 Ford E350 Remote module.
Hello everyone, new here!
I bought an 03 E350 XLT ford econoline, I'm in process to figure out about the whole keyless entry deal. It has power windows and power door locks. I'm trying to find if it has a remote module anywhere. I've called the Ford dealership here and provided the VIN to see if they can find out if it came with a factory remote or if it has a module. They said that they weren't able to find anything as it was an older vehicle.
I've tried looking for the module myself, under the passenger kick panel, passanger b pillar, and etc. No luck
Anyone know where the module location may be if it has one? Also the driver window does have a "viper" sticker on it, so maybe someone already installed an aftermarket module? If so, where will it may be located?
Thank you
Thank you
I found a video that explains it being under the passanger kick panel. Ive searched both areas, the driver and passanger kick panel sides.
Under the dash, left side, to the right of the steering column there are 3 modules mounted against the firewall . The 1st one on the driver's side is the
"Vehicle Security Module". That is where the module is that you are looking for. You will may need to remove some "stuff " to see them, but that is where it is located.
No wonder you couldn't find it !
BUT today after doing A TON of research, it turns out that the older e series have all that wiring either in the passanger A pillar, passanger kick panel or in the driver B pillar behind the driver seat towards the base (the entire sidewall needs to come off) meaning I need to take out the rear seats.
I didn't have time to do that today, for the B pillar. Most of the plastic is sun burnt and is really hard to pry without breaking. I will keep this updated with my progress. All I need to access is the remote module harness wires.
Sources -
https://www.thedieselstop.com/thread...e-shot.272488/
https://www.ford-trucks.com/forums/1...ry-module.html
https://www.2carpros.com/questions/f...-series-van--5
So I found out where it's supposed to be, I found all the wiring. It is all by the driver B pillar behind the sidewall, left of the driver seat belt at the base.
Ray167
05-17-2020 10:14 PM
