2007 E-450 Ambulance. 6.0L issues and "A" Post Crack!
Old 03-02-2012 | 12:17 PM
nbroetzmann's Avatar
Default 2007 E-450 Ambulance. 6.0L issues and "A" Post Crack!
I am the Maintenance Coordinator for an ambulance service in south east Wisconsin. I have a fleet to 5 ambulances, 4 of which are the 7.3L diesels and one 6.0L. The 6.0 is causing 90% of my issues. History: 2007 E-450 with the 6.0L Diesel with 95,000 miles. Horton Ambulance Box on the back with a GVW of 14,500lbs. I have had to replace 4 fuel injectors, 2 EGR valves, 1 EGR cooler, and 1 turbo. As of right now all that work has been warranted. Looking for advise now that the warranty is about to expire. The latest issue is the passenger side "A" post is cracked. Imagine the passenger side "A" post where it meets the roof line...... 4 inches back from that point a crack begins and goes up to the drip edge, the crack then goes forward to the windshield. It is cracked completely through, you can see it flex as we drive down the road. Iv taken it to a number of different auto body shops and a Ford Body shop. First off no one has ever seen this and secondly no one knows how to go about fixing it. Has any one ever seen this and if so, how do I go about fixing it.
Old 03-02-2012 | 01:14 PM
I'm sure you don't need to be reminded to have it on record before the warranty expires.
Since this type emergency vehicle is subject to strsses that some vehicles may never see, I would go after Ford or whoever you purchased it from for a complete new cab and chassis. This sort of thing is not supposed to happen and it could very well be due to poor workmanship on the manufacturer's part. In either case you're talking big bucks for a rig like this and municipal budgets don't provide for this sort of problem.
Go for it !!
Old 03-02-2012 | 02:00 PM
We are actually a not-for-profit organization so the money crunch is even worse for us right now. I have been going back and forth with Ford's Field Engineer and warranty clime specialist, its sounding like due to the age and mileage of this vehicle they are not going to cover any of it. I had the ambulance manufacture here 2 days ago to make sure it not on their end...... none of the ambulance box mounts or welds were broken so it appears to be a Ford issue. Keep in mind this ambulance was never in any kind of impact, the crack happen all by it self. If when all is said and done and Ford denies any clime......... what is the next course of action?
Old 03-02-2012 | 02:29 PM
Has Ford offered any kind of "good will Gesture" since the wrong kind of publicity would not be in Ford"s best interest?
Old 03-02-2012 | 07:40 PM
No, nothing yet.
Old 01-23-2013 | 12:27 PM
driverinlic's Avatar
Hey all, you should know about Sarad.com -- they're in Brooklyn, NY and stock a lot of parts of ambulances/ambulettes/Ford vans. (or they can get you parts direct from Ford, a lot cheaper than any dealer). They're really helpful guys, check out their website
Old 01-23-2013 | 12:32 PM
SARAD.COM makes it easy to buy whatever you need for a van-- here is a link to their "fleet store" Sarad Auto Part Fleet Store: Ambulance, ambulette, access-a-ride, paratransit, school bus, schoolbus&
Old 02-09-2024 | 12:37 PM
Wrenchone's Avatar
Default E350 2019-2005
I'm have the same issue. I have 5 2019 E350 .A 2014 E350 A 2005 and A 2006 all cracked at a pillar no help from dealer or ford.
All ambulances
Old 02-10-2024 | 12:25 AM
etinpa's Avatar
Wrenchone & nbroetzmann:
I think you two need to exchange info and communicate with each other (or have your lawyers talk).
Old 02-12-2024 | 07:54 AM
Wrenchone's Avatar
Default Cracked a pillar on ford's
Have 5 ambulances with this issue need some help.
