5.8 i poor performance and high fuel consumption
#12
This is the reader that I have been using for the last 25+ years.
https://actron.com/content/obd-i-code-scanner-ford
#15
The tool I am suggesting will allow you to do dynamic testing because that programming is already in the ECA.
It will run the engine, through a series of tests while you watch and listen, then will provide the codes for you to further check if necessary.
