'92 e350 motorhome left signal and brake light problem
Old 10-30-2012 | 02:01 AM
kmerritt's Avatar
Default '92 e350 motorhome left signal and brake light problem
The left signal and brakelight (yellow wire) is not receiving any power when either is used. The flasher, fuses and bulbs are all new and good. Any ideas ?? I was thinking maybe bad indicator switch in the steering column ?? Right blinker and brakelight works fine..
Old 10-30-2012 | 04:14 AM
Do they work with the hazard flashers? If not, would go after the signal switch assy in the steering col. Very easy to change, just remove plastic covers under steering wheel and two torx head screws and switch unplugs.
Old 10-31-2012 | 11:06 PM
kmerritt's Avatar
No it doesn't work with the hazard flasher, going after the signal switch now. Thanks !!
tomrj
06-18-2013 09:57 AM
Fizgig
12-02-2011 08:32 PM
SDodwell
11-12-2011 10:53 PM
Perk B
06-22-2011 10:25 AM
bud121156
06-27-2007 01:10 PM
