95 E250 Cant Turn Engine Off
Old 01-23-2011 | 07:54 PM
Bronco1990Scot's Avatar
Default 95 E250 Cant Turn Engine Off
I turned the key to shut the van off.. but it wouldnt shut off. I drove home, pulled the coil wire off.. and that shut it down. Thinking its the ignition cylinder, I changed the cylinder and keys.. but still have the same problem. It started..but when I go to shut it off.. the key just turns back..and the engine keeps running.
Instead of pulling the coil wire, I disconnected the ignition switch.. and that killed the engine. Should I change the ignition switch?
Bronco1990ScotView Public ProfileSend a private message to Bronco1990ScotFind all posts by Bronco1990ScotAdd Bronco1990Scot to Your Contacts
vBulletin Message Cancel Changes
David Oliva
09-26-2023 10:22 AM
Bronco1990Scot
02-01-2011 04:18 PM
justelmer
07-01-2007 08:16 PM
