back-up lights???
Old 05-18-2007 | 12:14 AM
dsljay's Avatar
Default back-up lights???
There are no back-up lights on our 1995 E350. Where do I find the switch that powers the back-up lights and/or what is the color code on the power wire ? We have temperarily hooked the lights to a toogel switch, but I want to fix them right. Thanks, Jay
Old 05-18-2007 | 01:18 AM
Default RE: back-up lights???
Back up light switching is done through the transmission range sensor.. Check for fuse failure as well.. I think this schematic is correct for your application..
[IMG]local://upfiles/6756/11771D52F40F4F498A07829084C8957F.gif[/IMG]
Old 05-18-2007 | 09:16 AM
dsljay's Avatar
Thank you, but where do I find the range sensor? Thanks again, Jay
Old 05-18-2007 | 12:48 PM
Range sensor is bolted to the left side of the trans, at the shift selector lever.. Should be similiar to this one pictured
[IMG]local://upfiles/6756/1087CF49D79A4469B3C76D57CC9CF5A8.gif[/IMG]
Old 05-18-2007 | 10:31 PM
dsljay's Avatar
Thanks again. That info will make this easy. Jay
Old 05-21-2007 | 01:46 AM
cn1790's Avatar
I read this about 2 days to late. The posted wiring diagrams are pretty much what I manually traced out except under the dash the rev light wire was blk w/grey strip and not blk / with pink as I noticed was hooked to the lights in back.
willy j
09-30-2013 07:42 PM
amberblues
12-28-2006 11:09 PM
F250LOVER
06-19-2006 12:26 PM
BadZX2
06-16-2006 03:44 PM
bastardchild
11-19-2005 10:34 PM
Quick Reply: back-up lights???
