Biggest tires on stock E 150
Measure yours from the center of the hub upward to your desired height, and then times 2 so you get the diameter. Once you get the diameter you can go to any online tire shop and shop by diameter.
When you upsize it too much (all the way and barely without rubbing) your speedometer is going to be off by 15-20 mph and then you have to calibrate your speedometer afterward, if at all possible.
