Can i switch from E250 to E150 coil spring
I have a 93 E250 cargo van but is too tall and cant fit my ladder rack because it will hit my car port. I was thinking that if i remove the E250 springs and install a set of E150 ones it will enable the van with ladder racks to fit through. Will the modification affect the ride and suspension in any way. Thanks
RE: Can i switch from E250 to E150 coil spring
You can put those springs on your van, but there are a few things you will need to consider. Yes it will drop the van down in the front, yes it will cure a little bit of your negative camber issue, yes it will drastically affect the performance of your braking system, yes it will make it ride a little softer. If I were you I would'nt rec'd it , but it can be done.
