can someone help with the metal heater core tube to backside of manifold?
i was looking for the procedure on replacing f75z 18663 ab heater core tube the one i found on google seams to be no good anymore so any help would be appricated thank you
its a 1997 e350 with the 5.4
I have tried online just to find the procedure from what I heard u need to remove the intake manifold I was really hoping for a easier way since the tube just fell off not sure on how it connects there is like no special fitring on the tube not sure if its on the manifold or what not
He's talking about the heater tube under the intake manifold in the engine valley. It should/would have been held in place with 2 bolts. Sounds like the bracket came loose from the tube, and the line has pulled back and off the block..
RedEric
04-26-2015 08:28 AM
