drives in Park and no Reverse
Old 11-17-2011 | 02:46 PM
econobug's Avatar
Default drives in Park and no Reverse
Today, I drove to pick up my cargo. I backed into the loading dock, loaded, and drove away.
My next stop was for fuel. My van reverse well into where I was to fillup.
I drove her home, where I noticed that while in Park, she would move as though in Drive.
And so, now, I have a van that moves in Park and I have no Reverse.
Any ideas?
Thanks,
Econobug.
Old 11-17-2011 | 04:15 PM
I don't believe the problem is in the trans.
It sounds more like the shift linkage has become loose somewhere between the shift column and the connection down at the trans. Check the bolts at the bottom of the steering column that control the shifting linkage. They are known to get loose and give the feeling of looseness with shifting and can affect starting too.
Old 11-17-2011 | 05:51 PM
econobug's Avatar
Thank you hanky.
I shall let you know what happens.
Econobug
Old 11-28-2011 | 10:06 PM
econobug's Avatar
I would have gotten back sooner with the results but I had to leave town for a week, and therefore have not had a chance to inspect the linkage.
Anyway, I arrived home and had to make some more deliveries, and so I figured out how to load without the use of reversing into the loading bay,
On my last delivery, I noticed that she grudgingly would try and engage reverse. That was yesterday.
Today, reverse is back, and I had done nothing to fix the problem. I did a delivery, but I was most cautious about where and how I parked.
Could there have been some other reason for loosing reverse other than the linkage.,
Thank you,
Econobug.
Old 12-10-2011 | 02:06 PM
econobug's Avatar
Well, she lasted ten days and then Reverse quit again. I adjusted the linkage, and MLPS but still no Reverse.
I just checked my fluid level and found it to be a little high.
I shall be draining some fluid out, and hopefully, this will cure the problem.
Thanks,
Econobug
maxpower
06-24-2013 09:58 PM
TIMF150
08-31-2012 12:51 PM
J3SS1
04-19-2012 11:39 AM
cindymac
03-24-2007 11:47 PM
