E-150 Fuel Problem
Old 12-20-2010 | 05:38 PM
mxtreme311's Avatar
Default E-150 Fuel Problem
I have an 88 E-150 I bought for a steal a few months back. Since I've had it the van will not use the front gas tank. If you switch to the front gas tank, the fuel gauge changes to the front tank, but it continues to use gas from the rear tank.
I took it to the dealership and they say it's the "Lift Pump" which I believe is the pump up on the fuel rail (not the pump in the tank) that is causing the problem. I'm fairly skeptical about this because if that pump was broken, wouldn't the rear tank not work either???
Anyone out there know anything about these two tank setups??
danco
08-06-2012 08:23 PM
PASBON
10-29-2009 09:57 PM
derby01
09-27-2007 09:46 AM
desi
07-07-2007 08:05 AM
whozat24450
03-26-2007 03:57 PM
