E 150 Rear End Swap
Old 10-14-2013 | 04:12 PM
fdorval's Avatar
Default E 150 Rear End Swap
Hi all,
Does any one know of a rear end I can swap out for my 2000 E 150 with drum brakes? I want disc on the rear. I was wondering if a F 250 or E 250 will bolt up with out any modification? I was told my van was built on a F 250 chassis with 1/2 ton suspension. Is that correct?
I am also looking into putting air bags to replace all of the shocks. Has any one done this modification and if so what vender did you use for the air bags?
Thanks Frank
Old 11-28-2013 | 06:29 AM
Moosey78's Avatar
As for the rear end question I assume you have an 8 lug rear end if so than you can not use a F series rear end. The lug pattern is different. Try and find a E series rear end
escaped-eric
12-23-2012 02:33 PM
dweber
03-01-2011 06:46 PM
CaptJack101
03-12-2008 01:30 AM
sincitykustomz
12-11-2006 01:37 AM
wpgbronco
11-27-2005 03:21 PM
