E150 Engine Removal
Old 10-21-2006 | 09:01 PM
todder's Avatar
Default E150 Engine Removal
I'm looking for any info on engine removal for a 94 E150 . Thanks alot.
Old 10-21-2006 | 09:29 PM
94 4x4 ranger's Avatar
Default RE: E150 Engine Removal
Welcome [hr]What kind of info are you looking for?
Old 10-21-2006 | 09:45 PM
todder's Avatar
5.0 engine, i have a crate motor and need to do the swap. It doesn't appear too bad but i don't want to spend a half day removing stuff not needed. I done a number of engine changes but never in a van Thanks
Old 10-21-2006 | 09:55 PM
Some they take out the front wich requires taking apart the front to get the motor out.[hr]Some take them out from the inside.
Old 10-22-2006 | 01:38 PM
CobbAE's Avatar
You must remove it from the front. You need to take out the radiator, condenser, front grille, and upper radiator support. There is not enough room to remove the engine through the inside cover area. It is rather easy if you have the time.
Old 10-23-2006 | 03:36 AM
Mulletman's Avatar
I have yanked out 6cyl engines and 7.3L diesels out of E-series vans before. Not too bad of a job and like the others said, it must come out the front. Good luck!
DanDanTechnoMan
06-10-2014 05:36 PM
bunklash
01-01-2011 01:04 PM
bread320i
03-17-2007 04:01 AM
Nitrofishing
05-31-2006 11:59 PM
robcat
04-18-2006 11:36 PM
