Ford e150 dual fuel
Old 09-01-2013 | 11:12 PM
Zeker's Avatar
Default Ford e150 dual fuel
Propane convert
Stalled and wont start on gas or propane
aeb computer system/landi renzo/impco fuel delivery set up
new plugs wires cap rotor
I am stumped
reset computers
checked grounds
Help I Have to go to work on M onday
Thanks for any help
Old 09-02-2013 | 05:13 AM
Did you have this problem before changing plugs and wires?
Did you replace the wires one at a time?
Old 11-30-2021 | 02:32 PM
Finelinefinisher's Avatar
Default E-150 in tank fuel pump connector
2007 e150,I’ve been having problems for a bout 3 days with going out to start the van in the morning and it won’t crank up instantly, couldn’t hear the pump,so of course start at the fuses and work towards the in tank pump,as soon a I opened it up and pulled the assembly out the tank I notice that the plastic electrical connection plugged into the pump is almost gone and the 2 wires running into it are fried
but not a single thing beyond the wires at the connector are burnt
Old 11-30-2021 | 08:03 PM
Poor connections with high resistance will build up heat and speed up corrosion.
The better thing to do would be to confirm the pump is not drawing excessive power , which if it is, replacement is necessary.
If current draw is within specification, might only be was a poor connection at the plug..
Felicia
06-14-2018 04:36 PM
luigi87
09-11-2013 12:40 AM
xgiovannix12
06-05-2013 07:29 PM
Kennysauto
07-02-2012 03:02 PM
Rouge Roger
01-07-2009 07:18 AM
