Getting Access to ABS Module (1999 Econoline 150)
My ABS light is on. I think it is a loose connection at the ABS module. (Long story I won't bore you with).
It seems the ABS module is attached below the Hydraulic Control Unit and very hard to get to. I am sure I have to move the HCU but it has a few hydraulic tubes connected to it and I can't remove those (cost for dealer to bleed the system) nor do I want to break one.
Does anybody know if things can be loosened up enough to get at the ABS module without damaging the HCU connections?
Thanks In Advance,
Pete
Thanks In Advance,
Pete
