interior light
First and easiest thing is to check all the uses. You can invest in a decent test light or multimeter and verify if each fuse is open by simply touching the tip of the test light to the top of both ends of each fuse If it lights on one end, it must light on the other or it is open .If you find one that is open,they don't just open for no reason. A higher current draw than the fuse allows will cause it to open to prevent damage. Some will require the key to be on to allow power to the fuse.
Do you think you want to try that?
Te fuse panel is located by the parking brake area up against the firewall. Not sure if your vehicle has an additional fuse panel due to extra facilities.
genx80s
11-13-2012 12:04 AM
genx80s
11-04-2012 01:49 PM
