No Spark
Old 02-08-2014 | 07:49 PM
I would suspect either you have a poor ground connection for the TFI module or the module itself is defective.
Are you able to have it tested at a local auto supply store?
On the TFI module should be a Blk/Wht wire that provides the ground for the module. That wire gets it's ground from the Org/Red wire that comes from the computer ign ground.
The dark Blue wire on the module gets the signal from the dist to trigger the ground for the module. These grounds need to be verified with the engine cranking so we know the pick-up coil in the dist is working.
  #12
Old 02-09-2014 | 10:35 AM
mrwarejr's Avatar
I figured it out.... One of the pins on the coil was bent out of place and not making contact..... WE HAVE SPARK AGAIN...
Thanks for all of the info...
  #13
Old 02-09-2014 | 05:20 PM
grindman's Avatar
glad you got it working again.
  #14
Old 02-09-2014 | 05:46 PM
I don't think he could mean the coil itself because we were all over that thing and he might be talking about a different part. Glad he got it going too.
  #15
Old 02-09-2014 | 06:02 PM
grindman's Avatar
I've heard that one could bend the pins on those plugs. not being careful while installing electronic parts can do that. it rarely happens but, it does happen from time to time
  #16
Old 02-13-2014 | 04:11 PM
mrwarejr's Avatar
hanky it was the two prong plug on coil the to be more precise. And grindman is correct, you must be careful especially with these order plugs and connectors. I will say I've found new appreciation for this forum. Got some great help..
  #17
Old 02-13-2014 | 04:34 PM
Now that you have updated your experience collection ,please don't be shy about sharing it with others in need on this forum, thanks !
Billy62
03-31-2014 05:08 PM
JCtrayer
11-22-2011 10:07 AM
JCtrayer
10-28-2011 05:32 PM
Rogerseric
08-12-2011 12:34 PM
67comet
01-01-2007 02:47 AM
Quick Reply: No Spark
