overdrive light flashing
Old 01-27-2011 | 05:57 PM
utz's Avatar
utz
Default overdrive light flashing
2003 e 350 check engine light on with overdrive light flashing.computer is reading that it is the range sensor is this a big job or does this sound like it could be something else.
Old 01-28-2011 | 07:58 AM
I believe you are referring to the range switch on the left side of the transmission. Its not a big job. Before you decide to replace it , remove the plug and check for corrosion at the pins and contacts.
Old 01-28-2011 | 04:17 PM
utz's Avatar
utz
ok i will thanks
tomcat5
08-10-2021 06:10 PM
Hudson
07-29-2010 08:56 PM
Tom Schlichting
05-09-2007 09:02 AM
ajrn
04-12-2005 06:16 AM
