Replacement rocker panels
I currently live in the RUST BELT, having problems finding replacement rocker panel, 2001 E-150 conversion van. Need the passenger side cargo door (swinging type) rocker panel.
any recommendations.
Thanks
Thanks
Rocker panels
I found a place that sells replacement body panels.
the Name of the company Is Mills supply.
My van has rocker panel rust and rear wheel arc.
I have many skills but one of them is not welding. I plan on fitting the panel by using a backing piece of sheet metal underneath to join the old and new sheet metal, using both panel adhesive and pop rivets. Once repairs are made take it to a welder.
