Replacing a door handle
Old 08-05-2008 | 01:26 PM
sdaniels7114's Avatar
Default Replacing a door handle
Hi, new member here.
Specs:
97 E-250 Triton V8
Front Pax side
I've removed the broken handle and the metal arm that extended upwards and mostly bumped the dents around the handle back out. The inner door cover is off. What's the next step? I can insert the new arm-handle combo into the hole and get the handle pretty much aligned over the rivet holes but I can't imagine how to attach the metal arm to the doo-hickey that actually unfastens the door. The old arm just screwed into that doo-hickey and I was only able to unscrew it because it was broken away from the handle itself. I can't see how to screw the new arm in without detatching it from the handle and if I detatch it it seems as though there'd be no way to re-attach it.
Old 12-17-2008 | 12:17 AM
goinstrong's Avatar
Default RE: Replacing a door handle
Some of the latch arms use a plastic slip clip (like an old 60's/70's,etc. throttle rod clip) to attach. Not sure if that's what you mean?? , but may have broken away/off on impact. Some of the parts may have to be riveted on with oversize rivets to reattach.
the wifes escape
08-06-2021 04:55 PM
HansonHVAC
01-12-2008 10:09 AM
4varellis@verizon.ne
12-28-2007 05:42 PM
trail user
06-10-2007 06:33 PM
Ranger96
06-07-2007 01:00 AM
