Transmission Linkage Problem for 1997 E-350 Econo Club Wagon
Old 09-20-2006 | 10:45 PM
BobD's Avatar
Default Transmission Linkage Problem for 1997 E-350 Econo Club Wagon
When I put the shift handle into reverse position, it's actually in neutral. I can get under the truck and manually shift the lever on the transmission into reverse and it will work. The cable seems to be stretched. When I put the shift handle into neutral, it actually goes into Drive. The transmission doesn't correspond to what the shift handle is indicating. As far as I can see, this is not a transmission problem, but a linkage problem of some sort. When the transmission is actually in the gear it's supposed to be in, it works perfectly fine, so I don't think anything is wrong internally with it. Can anyone give me advice as to what the problem is and how it can be rectified. Are there any adjustments that I can make to shorten or adjust the linkage to get it back to working for the correct gear again? I appreciate any information received on this matter. Thanks.
Old 09-21-2006 | 09:10 AM
94 4x4 ranger's Avatar
Default RE: Transmission Linkage Problem for 1997 E-350 Econo Club Wagon
[sm=welcomesign.gif]I would check to bushing's on the shift linkage for wear also check the shift indacator to make shure it is not hanging up.
Old 09-26-2006 | 11:36 PM
sean08's Avatar
Difficulty or not being able to engage in 5th or 6th or even in reverse is also a manifestation of a linkage problem. But sorry my knowledge is limited for any linkage adjustments.
Old 06-14-2007 | 11:50 PM
BobD's Avatar
Does anyone know what the correct name for the cable that connects the shift handle to the transmission for shifting?. I am trying to order this part from Ford but I do not know the part# or name to order it by.
natbr
05-29-2013 02:54 AM
whateversclever
05-27-2011 06:49 AM
Countrysinger
02-24-2010 04:04 AM
bdewilde
11-09-2008 09:25 PM
mdcar
04-29-2007 06:04 PM
