Will not start
Will not start
OK 2000 econoline conversion van..first incident waife at the mall turns key nothing no click just dash lights as usual ding ding..calls me I miss part of dover race and by the time I get there she has it running...second incident today she trys to start same thing..no alarm light..alarm seems to arm and disarm ok...tried second key just because same thing turn key dash lights ( oil,airbag,etc..) all looks good. moved selector through the gears..tilted the wheel up and down..dash lights dont dim like it would if it were trying to start so no juice is being sent to starter..relay maybe?
TECHMANBD ARE YOU OUT THERE ???
RE: Will not start
my mistake I was thinking the selonoid..ok I remember that part from my many other fords..plus I used to jump the two posts (along with a wire to the dist. i think) to hot wire dads old mustang when i was a kid..thanks again..
RE: Will not start
OK !!! power was at the SMR when the key was turned..jumped the selonoid and it cranked..so starter is good.. me thinks the SMR is bad ( so did HAYAPOWER )....will replace this afternoon..95% sure thats it..ill post results as soon as I can...
HAYAPOWER>>>> THANK YOU<<<<
