2007 Edge hard shifting
Old 12-23-2011 | 07:38 PM
RDietrich574's Avatar
Default 2007 Edge hard shifting
I have a 2007 Ford Edge with 43,000 miles. Over the past 7,000 miles I have had it to the dealer twice for a clunking noise when shifting out of first gear and occasionally when down shifting. Both times I was told they could not duplicate the problem and that there were no service codes so they could not help. Has anyone had a similiar problem? Any suggestions?
Thanks,
Rob
Old 12-29-2011 | 10:59 PM
masseyl19's Avatar
Default 07 Edge hard shifting
Hey Rob,
I have an 07 Edge FWD. In 2009 we had the same problem -- hard shifting going from 1st to 2nd gear. It was diagnosed as a faulty transmission controller and fixed under warranty. This week the same issue occurred again, only this time out of warranty (of course). It is the worst when going from park to reverse. It's the same diagnosis: a valve sticking in the controller; need to replace the controller for $1600+. Interestingly, ours started IMMEDIATELY after installing a new battery. Also, there is a TSB (technical service bulletin) for this model involving a transmission sensor that could cause a related problem. No lights came on with either incidence. Hope this helps!
Old 01-04-2012 | 10:40 AM
Douglas_48's Avatar
Originally Posted by masseyl19
Hey Rob,
If there is a service bulletin out then there is a chance it will become a recall down the line. You might be able to get them to fix it as "Good Will" and still get it covered. It almost sounds like it could be a software update too.
RDietrich574
12-25-2011 09:43 PM
debago
11-22-2010 04:51 PM
juangoodude
11-27-2008 10:21 PM
cjc4x4
04-20-2006 05:22 PM
cobrajet
01-30-2006 08:22 PM
Quick Reply: 2007 Edge hard shifting
