2014 Edge Headlights - Automatic Settings
Hello,
Has anyone dealt with the following issue before?
What should we be looking at before taking it to the service department? We just had to replace the water pump and cannot afford any more repairs at this time.
Headlights acting erradic when left on Automatic option.
Thank you for any information you can provide.
- 1 headlight remained on hours after car was turned off
- Now the headlights simply do not work in automatic position
- simptoms, sometimes one headlight will work in Automatic setting, sometimes neither and sometimes 1 headlight stays after car is off for hours
- Headlights work via manual on and off settings just fine, for now
- Replaced headlight switch
- Replaced headlight bulbs
- Disconnected battery for over an hour
