Weird transmission issue, Please help
Old 09-04-2013 | 10:11 PM
fireslayer26's Avatar
Default Weird transmission issue, Please help
So my wife's Edge has been having the intermittent transmission problem over the past year. Sometimes after stopping at a red light she would try to accelerate and the RPM's would go high and the car would just creep. Found out it was staying in high gear. A problem most likely related to the Output speed sensor or the Turbine speed sensor. Both on the tranny. This is what I found in my research and the dealership tech thought it might be. So I bought both sensors and replaced them today, along with a fluid change. But now, the car will only go in reverse. And its sporadic. It will engage reverse in R, D and L sometimes. Neutral is fine and Park is fine, but it never engages drive. Any thoughts??
Thanks!
Old 09-19-2013 | 09:39 PM
go-part's Avatar
Former Sponsor
Have you scanned for any fault codes?
The Symptoms of a Bad Transmission Solenoid | eHow
theunpaidBill
01-05-2014 09:26 PM
MrAndy1369
06-10-2013 11:27 PM
ludwikowski02
09-26-2012 10:32 PM
droz
01-15-2012 01:41 PM
H0meIsEverywhere
10-27-2009 05:41 PM
