2002 escape turn signals keeps blowing fuses
Old 08-25-2011 | 05:23 PM
crowedog's Avatar
Unhappy 2002 escape turn signals keeps blowing fuses
2002 ford escape blows fuses intermittently. replace the fuse drive a couple of miles then the signals wont work. seems to happen after you turn left. not a 100% sure. any ideas
Old 08-25-2011 | 07:56 PM
Lets try this, start with checking the left side front signal lite and the wiring to it.
If your vehicle has separate lights on the rear for signal lights, then you need to check that wiring also. If the signal lite on the rear uses the same bulb as the stop lite don't waste any time there because the problem would affect your stop lites also. There could be an intermittent short between the L/F signal lite and the signal lite switch on the steering column. Most of the time the light or the wiring causes the problem. You could always leave the left turn signal on and start moving the wires and watch for the lite to stop working in which case you may have found the area with the possible intermittent short to ground.
Old 08-28-2011 | 02:08 PM
miket's Avatar
i have 2003 f150 xlt tilt steering i use tilt everyday wires are breaking behind multifunctional switch at turn signal switch
Deadjester
06-17-2012 10:39 PM
wes032
11-29-2010 04:28 PM
chrisw
07-05-2010 03:25 PM
Litatude
10-19-2009 01:50 PM
help me
09-13-2007 01:39 AM
