2005 Escape ABS Ring Issue
My 2005 has had reoccurring problems with the ABS ring. Both times, the dealership replaced the entire axle (it comes as one assembly). The ABS light just came on again and I am thinking it is probably the same problem. I have over 96,000 miles on it, and was hoping to keep it for at least another 50,000 but if I have to continue to spend moocho bucks replacing the axle just for an ABS ring issue, I'll look at a different make altogether. I think its crazy that I've replaced the axle more times than the tires! Any input? Do the newer Escapes have a better design (ie the ABS ring NOT coming as one assembly)
aangel
01-16-2009 03:01 PM
