2009 Escape will not shift out of park
Old 10-29-2012 | 08:43 AM
msweeney's Avatar
Default 2009 Escape will not shift out of park
I have a 2009 Escape that will not shift out of park. After doing some research and finding out that the brake lights don't work either I think it is the brake light switch that either needs to be cleaned or replaced. I was wondering if anyone knew of a sight that could walk me through finding the brake light switch ( I know it is attached to the brake pedal, I just don't know exactly where or how it is attached ) as everything I read says this should be an easy fix that I should be able to do myself. I am pretty sure this is something my extended warranty company will as always say isn't covered due to normal wear and tear, so I would like to try this myself.
I appreciate any help on this.
Old 10-29-2012 | 12:02 PM
Welcome to the site..
Did you check the stop lamp fuse?
Old 10-30-2012 | 07:28 AM
msweeney's Avatar
Default Fixed!
So, after watching some interesting "How to" videos which were completely wrong, I discovered that the brake light switch was extremely easy to replace, taking less than 5 mins. Once I replaced the brake light switch my brake lights worked again and I was able to shift out of park. Thanks for your suggestion and I appreciate all of the advice that was provided to others in this forum which allowed me to easily fix my problem.
Old 10-30-2012 | 10:30 AM
Post
Thanks for the update..
angie07
07-02-2015 10:23 AM
maxpower
06-24-2013 08:58 PM
irishastro
09-27-2012 04:46 PM
kennylogel
09-23-2007 09:08 PM
93f250xlt4x4
11-05-2006 05:42 PM
Quick Reply: 2009 Escape will not shift out of park
