Ford Escape Tire Size question
I currently have my winter tires on atm but i have a set of aftermarket 17" rims that i will be putting on when the better weather hits. I want to give the truck a more aggressive off road look, so i'm looking to get some nice off road tires put on the rims. Now i know with the stock rims and rubber there is a fairly good amount of room left in the wheel well, can i put slightly bigger tires on without having a issue with rubbing when turning or hitting the wheel well from when going over larger bumps? if so does anyone know the size tire i can put on the 17" rims? they are 7" wide if that matters any.
Thanks
Thanks
