front end rattle
Old 12-11-2010 | 06:51 PM
beanox's Avatar
Default front end rattle
2002 Escape
There was a rattle in the front end when going over bumps, often worse when the bump was only on one side. I changed the sway bar links and the rattle went away for 4-6 months, but not it's back. I used Moog sway bar links and greased them when they were installed. Is there something else making the sway bar links go bad again that quickly, or what else would cause the rattle?
Old 03-11-2012 | 02:40 PM
casanova's Avatar
I have the same problem on my wife's 2005 Escape. Changed the sway bar links and still does it. Now I have to check the lower control arms-bushings and ball joints, struts and wheel bearings. I hope it's not the struts.
Old 03-18-2012 | 09:59 AM
Beagleboy's Avatar
Sounds like tie rod ends to me. Had the same symptoms on a Windstar once.
Old 03-19-2012 | 01:17 PM
casanova's Avatar
[quote=casanova;69783]I have the same problem on my wife's 2005 Escape. Changed the sway bar links and still does it. Now I have to check the lower control arms-bushings and ball joints, struts and wheel bearings. I hope it's not the struts.[/qu
Old 03-19-2012 | 01:33 PM
casanova's Avatar
Thanks beagleboy and Beanox. I found that the rattle came from the front strut boots. It looks like that over the years they've become dry and have shrunk in length causing them to come loose at the bottom end. I have wrapped duct tape (it fixes everything) around the bottom part of the strut where the boots touch, making the diameter of the strut bigger to decrease the clearance between the bottom of the boot and the strut, and "voila" the rattle is gone. I don't know if there are such a thing
as a strut boot with a zipper so that you don't have to take the strut apart to replace the boots.
hardbalance
04-12-2015 09:48 PM
makuloco2000
11-06-2014 02:13 PM
makuloco2000
10-06-2013 11:08 AM
roeboat109
08-22-2008 12:00 PM
rwehuman
09-20-2007 03:32 PM
