Help Deactivating Escape Automatic Door Locks
RE: Help Deactivating Escape Automatic Door Locks
Autolock and Horn Chirp Programming
Using the Keyless Entry Keypad (If Equipped)
NOTE: A manual enable/disable mode allows the autolock feature to be turned off and on.
Enter the 5-digit permanent entry code into the keyless entry keypad.
Within 5 seconds of entering the code, press and hold the 7/8 button on the keypad.
Within 5 seconds of Step 2, and while holding the 7/8 button, press the 3/4 button on the keypad and release it.
NOTE: If the autolock is disabled, the horn chirps once. If the autolock feature is enabled, the horn chirps once shortly and then sounds a second time for a longer sound of the horn once the above sequence is completed.Within 5 seconds of Step 3, release the 7/8 button on the keypad.
Using the Ignition Lock Cylinder
Close all doors.
Confirm that the key is in the OFF position.
Turn the key from OFF to ON.
NOTE: Steps 4 through 8 must be carried out within 30 seconds.Press the door lock control switch UNLOCK button 3 times.
Turn the key from ON to OFF.
Verify that the horn chirps. This indicates the system is in the enable/disable mode and is ready to accept program changes.
Press the door lock control switch UNLOCK button once, then the LOCK button once to toggle the autolock feature ON/OFF.
Verify that the horn chirps 1 time. There should be only one chirp indicating that the autolock/relock feature is disabled. If 1 chirp is heard, followed by a longer sound of the horn, the autolock feature has just been enabled. Return to Step 9.
Turn the key to the OFF position to exit the enable/disable mode.
Exit the vehicle and verify that the horn chirps once to indicate that a feature is changed and that autolock has been enabled/disabled.
Close all doors.
2010 Fusion..
Autolock and Auto-Unlock Programming
Programming the Autolock Feature Using the Door Lock Control Switch
NOTE: The autolock feature is not available on vehicles equipped with a manual transaxle.
NOTE: The autolock feature can be enabled or disabled independently of the auto-unlock feature.
NOTE: Make sure that the vehicle's perimeter alarm is not armed, the key is in the OFF position and the doors are closed.
NOTE: The following steps must be carried out within 30 seconds or the procedure will need to be repeated. If the procedure needs to be repeated, wait 30 seconds between programming sessions.
Turn the ignition key from the OFF to the RUN position.
Press the unlock button on the door lock control switch 3 times.
Turn the ignition key from the RUN to the OFF position.
Turn the ignition key to the RUN position. The horn chirps one time to indicate that programming mode is entered.
To enable/disable the autolock feature, press the unlock button on the door lock control switch then the lock button. The horn chirps once if the autolocks are disabled or twice (one short chirp followed by a long chirp) if the autolocks are enabled.
Turn the ignition key to the OFF position. The horn chirps once to signal that the programming is complete.
Programming the Autolock Feature Using the Keyless Entry Keypad
Close all of the doors.
Enter the factory set 5 digit entry code.
Press and hold the 3/4 button. While holding the 3/4 button, press the 7/8 button.
Release the 7/8 button.
Release the 3/4 button. The horn chirps once if the autolocks are disabled, or chirps once followed by a honk if the autolocks are enabled.
Programming the Auto-Unlock Feature Using the Door Lock Control Switch
NOTE: The auto-unlock feature is disabled from the factory on vehicles equipped with a manual transaxle, but can be enabled.
NOTE: The auto-unlock feature can be enabled or disabled independently of the autolock feature.
Press the unlock button on the door unlock control switch 3 times.
To enable/disable the auto-unlock feature, press the lock button on the door lock control switch then the unlock button. The horn chirps once if auto-unlock is disabled or twice (one short chirp followed by a long chirp) if auto-unlock is enabled.
Programming the Auto-Unlock Feature Using the Keyless Entry Keypad
Press and hold the 3/4 button. While holding the 3/4 button, press and release the 7/8 button. While still holding the 3/4 button, press and release the 7/8 button a second time.
Release the 3/4 button. The horn chirps once if auto-unlock is disabled, or chirps once followed by a honk if auto-unlock is enabled.
If you've lost your owners manual I found on the ford.com page you can join Ford Pass and download copies of your owner's manual. In it I found the instructions for discovering the keypad code on my 2017 Fusion. The car was a rental return and the owner's manual wasn't in it which had the 'magic card' with the key code on it. I think I remember seeing something in the manual about deactivating the autolock system also. They have many manuals that are current to you vehicle and downloadable. Hope this helps.
Code discovery procedure follows:
Displaying the Factory-Set Code
Note: You need to have two programmed keys for this procedure.
This is a copy and paste from Ford manual.
Note: The code may not display until after any other warning messages first display.
- Remove the key blade from the transmitter.
- Remove the rubber covering (A) from the cup holder. With the buttons facing upward and the unlock button facing the front of your vehicle, place the first intelligent access key into the backup slot (B).
- Press the push button ignition switch once and wait a few seconds.
- Press the push button ignition switch again and remove the key.
- Insert the second programmed key into the backup slot, and then press the push button ignition switch.
