Interior lights
Interior lights
Good evening,
I am trying to figure out what is wrong with my interior lights. They suddenly stopped working about 2 weeks ago. I replaced the appropriate fuses and they worked again for 2 days. Then, this morning, they did not work. Does anyone know the next step? (I haven't had a chance today to see which fuse blew this time) It seems to me that it's something electrical that is overwhelming the circuit and then causing the fuse to blow. I am trying to take care of this myself versus going to a repair shop to save time and money...two things I am very short on right now.
Thank you!
Thank you!
Did your vehicle have courtesy lights that came on when a door opened and with the interior light sw ?
Are these the lights you are referring to ?
Is there a switch at the light also?
Are there 2 under the dash and one in the roof ? If not, what does your vehicle have ?
Thank you. I'm sorry. I don't usually use message boards, but I know that they are a place to find people with much more expertise than I have.
So...
2018 Ford Escape SEL 1.5 L, 4WD Auto
the inside lights don't turn on at all, either by switch or by opening the door.
Thank you for your patience
So...
Your owners manual has loads of good info in it including which fuses protect what features and it can save you a lot of time and wasted energy.
It should describe the fuse(s) which are involved and a diagram of the fuse panels for interior/courtesy lighting. Once you know that you confine your efforts the checking those first..
Brokenrearlockactuator
05-20-2020 04:25 AM
lauraj
09-25-2012 11:23 AM
