P0401 CODE
Old 11-16-2006 | 10:24 AM
TYSONJR5's Avatar
Default P0401 CODE
DOES ANYONE NO WHAT WOULD CAUSE THE EGR VALVE TO READ A LOW OR INSUFFICENT AIR FLOW ON A 01 FORD EXSCAPE XLS V6 THE CODE IS P0401 ANY HELP WOULD BE GREAT
Old 11-17-2006 | 04:01 AM
Default RE: P0401 CODE
Was code P1408 present during a KOER (running test) as well? If there isn't a restriction in the EGR system, or EGR valve problems, vacuum circuit is good as well as wire circuits, and the vacuum regulator valve is functioning correctly, then the (DPFE) Differential Pressure Feedback Exhaust sensor for EGR flow is probably bad.. I've replaced more than few in various models.. It some cases the DPFE has been re-engineered.. Check the hoses at the DPFE for leaks, and the small manifold supply tubes for carbon restriction/s with compressed air or wire probe.. Most likely the DPFE sensor as they get pounded with exhaust emissions continuously, moisture contamination, and exhaust heat that corrodes the sensor inside...
Here's a image of the sensor..
[IMG]local://upfiles/6756/9E79FD62DDE34EA496B02253234FB37C.gif[/IMG]
Old 07-15-2023 | 01:21 PM
PLForney's Avatar
aI have the same issue on my 1999 Ford E150 I changed the sensor and removed the EGR valve cleaned that and the lines still getting the same code! What next?
jellybean66
05-19-2011 11:34 AM
fordalways
11-15-2009 07:42 PM
bodyman61
10-22-2009 08:37 PM
APS612
08-12-2008 09:18 PM
stone
09-03-2006 04:50 AM
