P1744 Trouble Code
P1744 Trouble Code
I keep getting 1744 code whenever im driving over 40mph for a period of time usualy 10-15 mins the o/d lights comes on and keeps blinking untill i restart my car. After i restart it it seems to work fine but when the o/d light is blinking car seems to jump everytime there is a gear change it isnt smooth.
Can it be an electrical or mechanical problem?
What would be the best sollution to the problem?
Hello,
P1744 is excessive TCC slip. Basically, the computer is not seeing enough rpm drop when the torque convertor locks up. It could be mechanical or electrical. When I get to the shop in the mourning, I will find out and let you know.
http://www.liangdianup.com/subpages/airfitting_1.htm
Now that is a lot of brass air fittings there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo burner.
