reverse lights wont turn on help 06 escape
Old 11-01-2008 | 04:53 PM
egomez22's Avatar
Default reverse lights wont turn on help 06 escape
changed bulbs and when in reverse the reverse lights wont come on, any suggestions??
thank you
Old 11-04-2008 | 09:00 PM
FJ11's Avatar
Default RE: reverse lights wont turn on help 06 escape
Check the "reverse lamp relay". Your owners manual will tell you where it's located, most likely under the hood in the fuse panel. This may also fix your parking sensor problem. It probably uses the same relay.
Mark
maxpower
06-24-2013 08:58 PM
nmwagschal
04-30-2012 12:54 AM
Triaxis
11-26-2011 05:01 PM
tedhontz
09-17-2008 11:57 PM
Quick Reply: reverse lights wont turn on help 06 escape
