02 Escort 4 Door SOHC low/rough idling and dies at red lights.
Old 03-03-2008 | 06:21 PM
shorty81's Avatar
Default 02 Escort 4 Door SOHC low/rough idling and dies at red lights.
Hello all!
I hate to make my first post on this forum a request for help, but I have an annoying problem. I've got an 02 Ford Escort, 4 Door, 2.0 SOHC with 170k that has recently started idling rough and dies at a red light occasionally. When it dies it takes multiple efforts to re-start.
I try to take pretty good care of the car. I put a set of new plugs in it this weekend in effort to fix the problem and it hasn't helped. The wires are less than a year old and are Motorcraft wires. I still have the original timing belt on the car and it has never been adjusted. I'm thinking of changing the PCV valve tomorrow. If any one has any suggestions or ideas my ears are open and I'd greatly appreciate it!
Thanks in advance!
Old 03-06-2008 | 05:20 PM
tomb1269's Avatar
Default RE: 02 Escort 4 Door SOHC low/rough idling and dies at red lights.
In a Chilton/Hayes manual you will find the specs and proceedure to check the IAC (Idle Air control). The IAC basicly take over for the TPS (throttel position sensor) when not in gear. In an automatic this is only while in park, so the symptoms will be rough up and downidle and stall while in park (hint for automatic owners, if you can idle fine in neutral and not in park guess what your problem is..........IAC). I assume you have a manual transmission, with a manual tarns the IAC takes over when your in neutral or clutched as at a light.
Jimboy311
06-11-2012 06:12 PM
tsjonesmusic1
09-12-2011 08:29 PM
Videoguybob
08-16-2011 09:19 PM
04f150dude
10-21-2010 07:15 PM
reb4life
08-29-2010 09:31 AM
