2001 ford escort zx2 A/C
Old 06-20-2015 | 09:45 PM
cj2001fordzx2's Avatar
Default 2001 ford escort zx2 A/C
Ok ive tried everything. thought I would give this a shot.I'll try to make a long story short. My ac went out on the zx2 we replaced the compressor and accumulator and still didn't work. replaced the ccrm and still nothing. replaced the clutch relay on the accumulator and still nothing. Today we bypassed the clutch ralay with a paperclip turned it on max A/C and the rpm's went up and the fan kicked on but the clutch still won't engage. does anybody have any idea what could be wrong. Help
Old 06-21-2015 | 05:55 AM
You have a choice of two things and they are to get your hands on either a test light or a voltmeter.
What you need to do is to confirm that power is available to the magnetic clutch on the compressor. Always check the fuses first !! There is usually a plug connection in the wire to the compressor. With a test light or meter , connect the test lite to that wire when the A/C is turned on, it should lite confirming that power is available to the clutch. If it doesn't show power to be available, now you need to backtrack to the cycling switch on the accumulator, then to the Switch in the vehicle. If no power determine where it gets lost.
If you find you do have power to the clutch, then make sure there is a good ground connection at the clutch. If you have both power and a good ground , the clutch is defective and will need to be replaced.
Old 06-21-2015 | 03:29 PM
thank you I will try that and let you know
Old 02-01-2020 | 08:33 PM
ltford2020's Avatar
you also have a high and low pressure switch that could be suspect
James1965
09-06-2018 06:22 PM
JohnathanDoe
06-25-2017 06:40 PM
GRANTOU812
07-16-2011 02:47 PM
seano5150
07-25-2010 06:50 PM
Mrlamo
05-26-2009 12:45 PM
