93 ford escort lossing power
I recently received a 93 ford escort stationwagon. I have had to replace the timingbelt,water pump, altanator, plugs, fuel filter and finally the fuel pump. Now the car with crank but wont stay started. I was driving home from work about a week after replacing the fuel pump and it just died in the middle of the road and wouldn't start. I let it sit in a parking lot for 24 hours went back to call a wrecker and it cranked right up. I know I need to change the ignition coil but what else could be going on with it? I need all the information I can get.
RE: 93 ford escort losing power
ORIGINAL: rachmor1
Hello and good day:
If you have a Bad Coil Pack (cracked, exposed...etc) would cause these symptoms. But youmention that you replaced the Fuel Pump recently....Check to make sure the connector harness?
blickman12
01-30-2013 04:54 PM
90EscortSTH
03-27-2011 11:27 PM
wetwilly
02-18-2008 02:15 AM
