94 escort 1.9 will not start
I have a 94 escort with the 1.9. I replaced the coil pack, timing sensor, ignition module. Still nothing it turns over fine but no spark. The check engine light doesn't come on when the key is turned on. I am stumped any help would be greatly appreciated... Thanks
RE: 94 escort 1.9 will not start
Turn the key to the run position and listen to a humming. That is the the fuel pump. It is very evedent in the escort. If there is No hum its youur fuel pump. If there is a hum or whirrr then you should replace the fuel filter. If you have to replace the fuel filter blow through the filter. If its easy to blow through then Im out of ideas.
