96 Escort will not start
Last week I had a charging problem with my Escort so I replaced the voltage regulator and my Escort alternator was charging again but I noticed the brush set was worn so I bought and installed those too. That is when my problems started, from that time forward my Escort would not start.
List of things checked or replaced:
I have no Spark
I replaced the coil pack
I replaced the alternator (did not have to be replaced)
Checked al fuses
Has anybody had this problem? What should I do next? Thanks for the help ahead of time.
I have no Spark
Checked al fuses
RE: 96 Escort will not start
I finally got the Escort running but it is running rough with the "Check Engine" light on. I had the codes pulled and here is what I got.
DTC P1443
EVAP Emission
Control Valve
Cntrl Valve Malf
What does the above mean?
Thanks
DTC P1443
EVAP Emission
Control Valve
Cntrl Valve Malf
Thanks
You just say "it won't start".
What happens when you turn the key?
Do you hear the starter actually crank?
Do all your dash lights come on properly?
If you're not getting the starter to crank, my guess is your battery is too low to get the starter to crank. Have your neighbor give you a boost.
