Cant get the gear out of park without manual override or turning on headlights?
Old 03-20-2009 | 09:01 PM
taylormah's Avatar
Default Cant get the gear out of park without manual override or turning on headlights?
On my 1996 ford escort automatic, once I put the car in park, I cant get it out of park unless I do a manual override by inserting a pin the the hole next to the gear stick. Normally I should be able to depress the break pedal and it would lit up the dashboard backlights and release the solenoid. But now, nothing happens when I press the break pedal - dashboard backlights dont lit-up and solenoid doesn't click, so gear shift gets stuck in park. But if I turn the headlamps on, it lights up the dashboard lights, I hear the solenoid click sound, and gear shift easily moves out of park. So for now, whenever I have to get the car out of park, I either do manual override of gear or turn the headlamps on. I cant pin point where lies the problem. It feels as if the electrical connection between break pedal and the gear box is broken, but I am no expert. Can you guys speculate what could be the problem??
Thanks for your input.
gusco911
09-09-2011 06:22 AM
Elayne
08-21-2011 01:57 AM
homedepot
05-31-2009 12:18 PM
Snip931
01-15-2009 11:14 PM
rlevy64614
09-25-2008 10:13 PM
