iac location?
Old 04-04-2006 | 10:32 AM
mr2 in nl's Avatar
Default iac location?
could someone tell me where the iac is located on a 1.9 94' escort...is it on the air box, throttle body or elsewhere...a picture would be great thanks.
Old 04-06-2006 | 07:28 PM
paintedwagons's Avatar
Default RE: iac location?
hi, why do u want to find it?
Old 04-08-2006 | 11:02 AM
mr2 in nl's Avatar
engine surging only when cold
Old 04-19-2006 | 06:17 PM
hi, have u tried cleaning the throttle body? u need to clean this first, as this may be the problem. location is, find the air filter box. follow the big fat hose comming out of the air filter box towards the engine. undo the jubilee clip that holds it on and pull back the hose. u should mow see a brass coloured disc sitting in a hole. it is about 2 inches in diameter. muck builds up around the circumference of this disc and also the edge of the hole, this reduces the amount of air that the engine takes in and could cause the problem. clean it with carburretta cleaner or brake and clutch cleaner. mick
Old 07-30-2006 | 12:03 AM
mr2 in nl's Avatar
by the way..cleaning the butterfly in the throttle body worked, thanks!!
thefrog
03-14-2016 08:47 PM
groho
08-26-2007 02:29 AM
Mike Hickman
07-04-2007 06:29 PM
kevhed
01-16-2007 02:06 PM
fred_penner
10-28-2005 03:41 PM
