Rear brake drums
I do not remember the size bolts to use, but your main concern will be to be able to back off the self adjuster if you have to, in order to remove the drum. Unless the drum is rusted to the hub a few clunks with a hammer will usually break the drum loose from the hub. You may not need the bolts to remove the drum . Many times prying evenly on two sides will get the drum off
