Vibrates @ stop in drive...
Old 06-30-2004, 11:18 AM
DanH's Avatar
Default Vibrates @ stop in drive...
'95 Escort, Automatic.
When I come to a stop with the car in Drive, it will vibrate noticeably, but when you flip it into Neutral it goes away and idles fine.
Vacuum or Sensor???
Old 09-03-2004, 08:54 AM
Default RE: Vibrates @ stop in drive...
it is probably a vacuum line. At least that is what I have experienced in the past. If the check engine light is on then start looking at a sensor.
Old 04-25-2005, 08:56 PM
my '99 automatic escort tends to vibrate alot in drive but is fine for the most part once its in park. would this be the same kinda problem?
Old 07-09-2005, 06:50 PM
If the engin light is on and the vheical has more than 120,000 miles chech the O2 senseror.
Old 07-20-2005, 07:15 PM
I hate to be the bearer of bad news but the concern you have is probably normal. The 4-cylinder engine in the escort is known to have a bad vibration, especially felt in the steering wheel at a hot idle in drive and worse with the a/c on. The good news is that the little cars run forever if you keep up on your scheduled maintenance.
Old 07-21-2005, 01:21 AM
Yeppers tough lil motor.they will run an run !!!!
Old 08-25-2005, 07:40 PM
yah my '94 auto deffinetely does the same thing..vibration is pretty bad but yah its normal..annoying but normal
Old 12-08-2006, 01:12 AM
MY 1998 FORD ESCORT WITH 150,000 MILES DOES THE SAME SHAKING MOVEMENT BUT IT GOT WORST THE PAST 2 YEARS WHATS UP WITH THAT
Old 12-22-2006, 06:25 PM
Possibly motor mount defect, maybe?
Old 01-20-2007, 04:39 PM
I agree with Jesusjeep19. It could possibly be a motor mount. My girlfriend's car begins to vibrate at the light sometime after the car has warmed up. Not TOO bad, but the culprit was a bad motor mount.
Quick Reply: Vibrates @ stop in drive...
