what is the compression psi spec for 96LX 1.9
Hello Folks,
Does anybody know the compression psi spec for 96LX 1.9L?
I'm getting 120psi on #1, 90-100psi on #2, 120psi on #3, and 150psi on #4.
Also, the Haynes repair book has the goofiest way of doing a compression check.We ignored their way andjust checked one cylinder at a time - leaving the other three sparkplugs connected. Though, we didn't disable the coil or hold the throttle to full open.
Does anybody also knowanother method of doing a compression check? From what I've looked up, this is the proper way:
[*]Make sure the engine has been warmed up before beginning the test, to ensure that the oil has been warmed up. A cold engine will not test correctly.[*]Disable the ignition module or coil.[*]Insert the compression tester into one cylinder spark plug hole at a time.[*]Hold the throttle to full open position to ensure the engine gets adequate air intake.[*]Crank the engine continually for at least five to 10 full revolutions to obtain an accurate reading on the compression tester.[*]Record the reading for each cylinder. If any of them vary 10 percent or more from each other a problem may exist in one or more cylinders. If the variance is greater than 10 percent, specialized testing equipment may be required to fully diagnose the problem.[*]If all cylinder readings are within 10 percent of each other, no further testing is required and compression is considered optimal.
Thanks for any and all help,
Mike
Mike
RE: what is the compression psi spec for 96LX 1.9
ORIGINAL: myothercarsaporsche
Hello Folks,
Does anybody also knowanother method of doing a compression check? From what I've looked up, this is the proper way:[*]Make sure the engine has been warmed up before beginning the test, to ensure that the oil has been warmed up. A cold engine will not test correctly.[*]Disable the ignition module or coil.[*]Insert the compression tester into one cylinder spark plug hole at a time.[*]Hold the throttle to full open position to ensure the engine gets adequate air intake.[*]Crank the engine continually for at least five to 10 full revolutions to obtain an accurate reading on the compression tester.[*]Record the reading for each cylinder. If any of them vary 10 percent or more from each other a problem may exist in one or more cylinders. If the variance is greater than 10 percent, specialized testing equipment may be required to fully diagnose the problem.[*]If all cylinder readings are within 10 percent of each other, no further testing is required and compression is considered optimal.
Mike
Hello Folks,
Mike
I would suggest the you look further into the Head Gasket replacement. Or your Piston Rings... How many Miles does this 1.9L have???[sm=americanasmiley.gif]
Michael Leonard Woodcock
12-10-2012 08:36 PM
GTBrian
07-17-2012 10:31 AM
150psi, 19, 96compressionpsi, check, compresion, compression, engine, escort, focus, ford, gt, psi, readings, taurus, v6
