2002 Ford excursion door ajar light on
Old 07-21-2009 | 07:18 PM
supportfop's Avatar
Default 2002 Ford excursion door ajar light on
I cant figure out why the door ajar light in on as well as the dome light and floor board lights. All the doors are closed and tight. I can't find out where the sensors are located to see which door is the problem.
Old 07-23-2009 | 06:50 AM
Use Common Sense's Avatar
Spray all of the door latches with silicone spray. The light switches are built into the latches. These will tend to hang up causing the issue.
mike 96 ws6
09-25-2012 09:25 AM
mholder
10-03-2011 07:03 PM
oceanblue_2001
02-27-2010 06:16 PM
Zapman
02-16-2009 07:29 PM
Mike11C
05-27-2007 03:14 PM
